LSD info needed.......
From Seattle ,WA.
the wiki says this - " There is one LSD for ratios up to 4.111, and another for the larger ratios " - is this true & does it mean one could use a H145 LSD in a H150 housing/carrier & connect the 150mm ring gear to it along with the pinion gear as well.
any info appreciated!
Posted on: 2010/3/8 5:25
Re: LSD info needed.......
H190 was used in most of the Datsun pickups, the 1960's Datsun Roadsters and other Datsuns.
Axle baffles and Oil Coolers were available from Nissan Competition
Unknown but I doubt it. The H145 LSD is designed for the H145 carrier.
Posted on: 2010/3/8 6:06
From Seattle ,WA.
I guess I mis-read that, I assume that statement is specific to the H190 rearend then only ?
Posted on: 2010/3/8 15:17
Yes, H190 only.
Posted on: 2010/3/8 17:29
From Las Vegas USA
Ed I checked the motorsports catalog
H145 L/S assy # 38420-H1020 , H150 L/S assy #38420-A1265
H145 ratios: 3.9 , 4.11, 4.375, 4.625
H150 ratios: 3.545, 3.70, 3.889, 4.11, 4.25, 4.375, 4.625
All of the pieces parts for the H145 & H150 LSD are different.
Tom
Posted on: 2010/3/10 4:02
