« 1 (2)
Re: fs: collection of rare and hard to find bits plus a complete kb10
From Darwin NT
BUMP
cmon guys need this stuff gone and need some money
and i am not going to split the a10 from the coupes so dont ask
Posted on: 2010/2/14 10:58
current project 4x4 patrol...
datto1000wagon wrote:
and also for sale is an a12a bottom end this is basicly a 1300 once bored out is the larger cubed a12 basicly
bottom end only no head has been out in the weather so the bore is rusty still has oil in the bottom end so its not all nasty and rusty in there the bore has a lip so it needs to be bore anyway
These are a top little motor if you plan to build up something special & want to keep it in the 1300cc class.
[A14/15's must compete in the 1600cc class so are at a disadvantage there]
The A12A uses a unique [to A series] 75mm bore size, however the 76mm pistons from the A14 are only 2 oversizes up on the standard bore so the block will be guaranteed to handle this size.
The best part is that these engines use the shorter A12 rod but with the larger 19mm wrist pin so the A14 pistons will slip right on without any mods to the rods.
If you go to the A14's first oversize [76.5mm] you will get 1287cc which is close to, but comfortably inside the 1300 limit & this is still a standard oversize for the original A12A block.
The original A12A head was nothing to write home about so use an A14/15 head & a mild cam with a single downdraught Weber on a water heated manifold with extractors/headers/branches [pick one] & you have a damn good little engine with a LOT of development potential.
You snooze, you loose.
Posted on: 2010/2/14 13:01
Love your Datsun.
Treat it well.
From Darwin NT
bump bump bump need this stuff gone now.
gx head and carbs spoken for
also for sale 1200 ute diff with bluebird disc brakes mounts moved for 1000 centre welded ideal for 1000 race car
will throw a 2 bare 2dr sedan shell ideal for a race car has partially complete front end and rear springs with new bushes in the rear. chasing 500?? is rusty in the sills and frontend needs considerable repairs the rad panel is smashed up but isnt structural (chassis) can load onto trailer with fork lift
Posted on: 2010/3/1 6:42
From Darwin NT
bump
need to get money guys....
need to pay back some money so the gear has to go...
Posted on: 2010/3/4 12:00
Wish I could help out somehow chief but I have several 'owe-ings' myself.
Good luck with the sale. Pull that digi-camera out and snap some pics, this is a visually responsive society we live in so pictures really do speak a thousand words.
Posted on: 2010/3/4 12:10
From brisbane
Hi mate
Do you have any spare KB10 tail lights?
Thanks Matty
Posted on: 2010/3/4 12:11
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Darwin NT
chris i would if i could im 500kms aways from everything and without a car
BUMP
FFS!!!! i need money and i need this gear gone NOW!!!
make an offer!!
Posted on: 2010/3/16 6:12
From Freo
put pics up of the toys bro.. eye candy always works..
what wheels you got to palm off?
Posted on: 2010/3/16 6:19
A15 PSI Project Motor
'72 CB750k,
From newcastle, NSW
yeah! What he said!
What have you got left?
Posted on: 2010/3/17 9:26
« 1 (2)
