arp main studs-wrong part number?????
From bathurst nsw
hi guys i rang up rocket industrys after an arp stud kit for the little a15 and i quoted:
head p/n: 202-4203
conrod p/n: 102-6002
main p/n: 202-5401a and apparently the main part number is wrong, arp doesnt have a listing for the a series but it will come up with nissan a series for the conrod and head stud numbers.
if anybody could help i need to order the by tomorow afternoon so its pretty urgent. maybe should i try fabre or vpw?
thanks kurt
Posted on: 2010/3/15 10:33
My car gets me from A to B...Just faster ;)
Re: arp main studs-wrong part number?????
From Bathurst - NSW
Posted on: 2010/3/15 11:08
That's correct. ARP knows their stuff, and they don't have Main bearing cap bolts kit for Nissan A-series engines.
Some guys use the ARP main bolts for BMC A-series engine in their Datto motors.
Posted on: 2010/3/15 22:43
From Vancouver, Wa
try it with out the (a) on the end
202-5401 this is for the L4 series I believe it is the same but not positive
Posted on: 2010/3/16 2:16
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Are you after main cap STUDS [recomended] or main cap capscrews [aka bolts]?
By using a sample main cap capscrew you can measure out the length & add a suitable amount for a nut & washer. Naturally you also need to measure the diameter & the existing threadform which will be a standard metric size anyway.
With these dimensions it may well be possible to select a suitable stud from their range.
I have main cap studs but
A. I cant find then after a quick 'blokes' look.
B. I have not yet fitted them to confirm that they are the correct ones.
Posted on: 2010/3/16 11:55
Love your Datsun.
Treat it well.
From bathurst nsw
hi guys. Yes dodgeman im after a mains stud kit not a bolt kit. I recieved my head stud kit and conrod bolts today. The L series number is different but only by the last number so ill try without the a on the end. Has anybody got an L series main bolt they could measure for me? Thanks
Posted on: 2010/3/16 12:24
From bathurst nsw
does anyone have any extra info. i had a look at my main bolts, they are m12x1.5. does anyone know if the l series are the same?
Posted on: 2010/3/17 8:33
From Vancouver, Wa
called nissan today both the a-series and the l-series both use part number 12293-18001 for the main cap bolts, so in reply you can use the arp main stud kit #202-5401 on either an a-series engine or l-series engine.
Posted on: 2010/3/17 19:43
So let's see: The A-series already uses main studs that are strong enough for an L-series engine.
Then why bother to buy the ARP studs?
Posted on: 2010/3/17 21:11
From Vancouver, Wa
why not? good peace of mind maybe, if you are really going to build something.
Posted on: 2010/3/18 2:06
