Head Cleaning
From Lisboa-Portugal
How do i remove the old gasket remains in the A14 cylinder head? Can i sand it or scrap it or do i use some kind of product to clean completly the head? The head doesn`t have any warp it was just a blown gasket. Can i do it myself or give it to a specialize shop?
Thank in advance!
Posted on: 2010/3/17 10:07
Re: Head Cleaning
From SE Melbourne
In Australia we have a product called 'gasket cleaner' it's a spray that dissolves gaskets then you can just gently scrap it off with a tool we funny enough call a 'gasket scraper' - both are available from auto shops here...not sure about portugal.
Posted on: 2010/3/17 10:50
Mildman, Datsunless
Re: Head Cleaning
From Newcastle nsw
I also scrape the majority of gaskets off with a razor blade, then clean the gasket surface areas with a scourer type disc that attaches to a die grinder. with this u gently go over the entire area evenly and they come up like brand new.
http://solutions.3m.com/wps/portal/3M ... =FMP22LCBMKbeSQSFJR0R56gl
Posted on: 2010/3/17 10:54
Re: Head Cleaning
I think we have that product here, but can i use other products like solvent and/or oven cleaner like product?? Thanks
Posted on: 2010/3/17 11:55
Re: Head Cleaning
Yes, use a solvent called "gasket stripper".
I use a putty knife, sharpened along its edge. I wouldn't use a buffer or sanding, to prevent dust from getting in the engine.
Posted on: 2010/3/17 15:55
Re: Head Cleaning
Thank you.
Posted on: 2010/3/17 17:21
Re: Head Cleaning
From Logan, QLD
Use a very sharp chisel, keep it sharpened and use at a very light angle. Be careful not to dig into the head, I found this works best, some of the old rb30 inlet gaskets were adhesive and very hard to get off, this worked a treat for those.
Posted on: 2010/3/17 21:18
