Carby rebuild
Hi all.
Im about to try and attempt for the first time in my life to rebuild (with my trustee ol skool workshop manual) the A12 carby that I pulled apart and thouroughly....
since its a first time attempt at any carby...any tips??
cheers
Posted on: 2010/3/19 7:50
Re: Carby rebuild
From Christchurch. NZ
a clean bench, an pull it apart on a clean rag so the bits don't roll off the bench, and put it back together the same day.
Posted on: 2010/3/19 8:51
Re: Carby rebuild
From Sri Lanka
Hi dori1
Cheers... If you are very confident about it , if not you may forget it working again properly.
Thanks
Regards
sumith
Posted on: 2010/3/19 9:03
Re: Carby rebuild
--confident.hell no, its my first time at rebuilding anything mechanical
rebuild the same day---i had to wait 4 days for gasket kit.
may as well sink down a slab and pray i guess..
cheers for tips.
Posted on: 2010/3/19 9:42
Re: Carby rebuild
From Sri Lanka
hi dori1
ok, don't be discourages, effort and likeness can do lot of things properly.when i joined this forum i was nil, but now i am very confident on what i am doing by myself.
Thanks
Regards
sumith
Posted on: 2010/3/19 9:52
Re: Carby rebuild
Im not too discouraged...this is the first time I am doing it by myself. I have been doing up another for the past 12 years...only this time save on paying some other mechanic. The car only cost me $300 and worked fine.....but I thought that rebuilding it with my own hands would be pretty cool. if worse comes to worse go blow $800 bucks on some webber thingo maji!..i got another toy for the track if this fails....but it wont...with great help from people on this forum I hope.
Posted on: 2010/3/19 10:01
Re: Carby rebuild
get a few cans of carb cleaner spray, and really go to work cleaning it. It might not help it work much better, but at least it's easy to put together and do any adjustments on (and also if it starts to leak or anything, you can see it easily on a clean surface)
Even the smartest carb guy in the world started exactly the same way. At one time in their life they had never worked on a carb and they tried it the first time. So you have got the same starting place as they had too, you can do this! And if anything goes wrong, people here can help.
Posted on: 2010/3/22 7:14
John McKenzie
