Lipped gards
From Wellington
Hey, has anyone lipped/ flared front gards on a 1200, if anyone has any tipps on this using basic tools.....thanks
Posted on: 2010/3/29 8:46
Re: Lipped gards
From Melbourne, Australia
theres a few photos showing my process in my build thread
i glued fiberglass flares on them skimmed bog over to flush them in
Posted on: 2010/3/29 8:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Lipped gards
From Canberra
If you just want to bend the inner lip up inside the guard, I just heated around the area with a hairdryer then just gently ran around the guard with a length of pole gradually increasing the angle until it was bent right up. It didn't crack the paint when I did it.
Posted on: 2010/3/29 9:11
YLD.18L
Re: Lipped gards
From Wellington
Well thats a use for a hair drier I did,nt know about.
Rallycar I did,nt see your gards in your buld thred, but I want to turn you thr lip and a slight flare working the metal.
Maybe if I try the metal bar I can turn the lip over and keep going and make a small flare........
Posted on: 2010/3/29 9:19
Re: Lipped gards
oh yeah for sure, done that plenty of times too, the rally car is like that. get a base ball bat and lever it against the tyre and the guard, slowly rotate it around working around the guard to lip it, then keep working it harder and harder to start stretching the gaurd out
factory paint survives it quite well, paint jobs done afterward tend to suffer cracking and flaking from it
Posted on: 2010/3/29 9:24
1200 Coupe Rallycar
Re: Lipped gards
From Wellington
I had a base ball bad once and I have just taken my scrap metal including metal bars to the scrap metal dealers, but that sounds like the way to do it, will hunt around for the right tool for the job.
I am repainting the car but why is it that paint jobs after this mod dont last......
Posted on: 2010/3/29 9:32
Re: Lipped gards
From Wellington
Hope these pics load up, but this the result
Posted on: 2010/3/30 10:18
