how do you remove the battery shelf in a datsun 1200 ute
From Canberra, ACT
hi im trying to remove the battery shelf if thats what is called in my car as i am relocating the battery to make room any ideas?? thanks
Posted on: 2010/3/29 10:24
Re: how do you remove the battery shelf in a datsun 1200 ute
Hey Dude,
The intercooler piping runs behind the battery so you don't really have to move it for that reason.
But if you want to remove it, normal practice is to 'drill out' the spot welds that hold the tray in place, you then weld up the drilled holes where the spot welds were and sand down the welds to get it all looking flush and smooth.
Tell you what, you might want to get to pulling apart a stock dizzie and locking/removing the centrifugal weights. You don't want any detonation....
Chris
Posted on: 2010/3/29 10:34
angle grinder and a set of goggles
Posted on: 2010/3/29 10:46
From Canberra, ACT
anything else i should be doing also how do you do that lol??
Posted on: 2010/3/29 10:47
From Canberra, ACT
yeah was gonna go the grinder and goggles idea but only have a 9inch lol im gonna leave it in there if i dont have to move it for the intercooler piping..
Posted on: 2010/3/29 10:49
Grider, goggles, VB Longneck.
Nah leave it for the time being.
I'll see if I can pull a dizzie apart here and get some pictures. I had one in the kit but it got fried the other day, that's why it wasn't included in the auction.
Posted on: 2010/3/29 10:51
From Sydney, Australia
It is hard to get out in one piece by drilling out the spot weldeds. There are at least 15 spots to be drilled out. The platform foot on one corner is very hard to get a drill into it.
Drill out as many as you can, and let the angle grinder do the talking after that.
Posted on: 2010/3/29 10:53
From SA
buy your self a spotweld drill bit,
drill out the 15 or so spots, you can make them visable by rubbing the perimeter of the tray with emory (sand paper) showing little rings, then drill gently, not going through both pannels... slide a screw driver between spots and drill away mate then just linish off the wheel arch.
cheers Dan
Posted on: 2010/3/29 10:57
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
From Canberra, ACT
haha VB!!! grosss na a carlton for me
From Canberra, ACT
yeah i might look for one of those drill bits as i tryed with a 12mm drill bit i can see the concrete now haha
Posted on: 2010/3/29 10:59
