(1) 2 3 »
Temp sensor removal.
From Perth WA AUS
I know this has been covered before but I can't find the info I require, When trying to remove my water temp sensor the outer threaded part unscrews and leaves the inner core securely attatched to the head.
The question is should I try and pull it out or do I need to remove the head?
Oh and its the stock water temp sensor in an A series head.
Thanks in advance :)
Posted on: 2010/4/14 14:56
Datsun 1200 2Dr sedan.
Re: Temp sensor removal.
From mandurah
Drill it out !!!
Posted on: 2010/4/14 14:58
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Yeah but I would like to avoid crap in the coolant and or removing the head.
Posted on: 2010/4/14 15:03
From mandurah
yea but nthe good thing about removing the head is you will get to find out what internals your running
then it wont be such a mystery
Posted on: 2010/4/14 15:20
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Freo
soak it for days and days with crc.. it might loosen up, but you'll still need to replace it..
Posted on: 2010/4/14 16:13
A15 PSI Project Motor
'72 CB750k,
From Atlanta, Georgia
Ouch... That's not suppose to stick in there.
Pulling the head isn't a half bad idea though. You can get an idea of what condition the rest of your engine is in.
Posted on: 2010/4/14 18:49
1981 Datsun B310
1973 Honda CB175 K7 Cafe
From Perth WA AUS
Maybe if I unscrew the outer bit again & run the engine till its nice and hot it might blow out on its own!
But surely vise grips would work.
Posted on: 2010/4/15 7:40
From Freo
having the head off won't help you get the sender out at all...
Posted on: 2010/4/15 7:42
'72 CB750k,
From Perth WA AUS
Thats what I like to hear, I want my wheel!!!!!!!!!!
Posted on: 2010/4/15 7:49
This is actually quite common: they stick in the head.
Dundee is quite right, removing the head won't help at all.
Just use vice-grips to twist & turn until it comes out.
Posted on: 2010/4/15 8:10
(1) 2 3 »
