(1) 2 3 »
How to lowered 1200?(with pillowball)
From Malaysia
Hi guys..
After installation of the pillowball,my ride is higher like 2"...
Luckily i can adjust the height wif my pillowball...
But i think is still too high juz like std height even after the adjustment...
With shorten 1 1/2 coil Rear S14 spring,i manage to lowered it a bit compare to std height but im thinking to lowered it down like 1" more...
But the problem is,the stroke of the absorber already too little like oni <3" play...
Any solution for me to lowered it more but still maintaining those original parts?
jpg  1.JPG (26.22 KB)
9396_4bcbabafd432e.jpg 512X384 px
Posted on: 2010/4/19 2:02
Re: How to lowered 1200?(with pillowball)
I doubt it mate. By the sounds of things your not using a coil-over type suspension which in most cases now are height adjustable at the very bottom. This may be your only option otherwise to ditch the pillowballs or shorter stroke shocks.
Can anyone confirm?
Posted on: 2010/4/19 3:54
From Malaysia
i must use the pillowball to get the -ve camber i needed..(now max -2.5deg)
replacing it wif std rubber top mount wif -ve camber will wear out the rubber fast,correct me if im wrong...
Posted on: 2010/4/19 4:16
B110 1972 Modded A15
Not necessarily, it does depnd on how the rest of your suspension geometry is setup but the diff in wear shouldnt be that noticable.
Posted on: 2010/4/19 5:12
From Oberon NSW {Bathurst}
To get your car down around 1" under spec and be able to super fine tune camber and caster the full coilover setup is the way to go. Matching your spring rates, shock deflection and swaybar torque will go along way to making the little beast handle like a go-kart. Have a talk to your local suspension shop people or get in touch with the techs at King Springs ( www.kingsprings.com.au ) I am sure that they can help you out.
Posted on: 2010/4/19 5:32
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Shouldn't those camber plates be on top of the strut tower, instead of underneath?
Posted on: 2010/4/19 6:14
No... well mine arent anyways and i have ISC N1 coil overs
Posted on: 2010/4/19 6:30
From Malaysia
ddgonzal,those camber plates i seen in our place were install beneath the strut tower. Do u hv any pix bout those tat install above the tower? Might give me some idea...
Posted on: 2010/4/19 8:04
From Adelaide, Australia
So what mods have you made? What does your suspension consist of? So you took out the original rubber tops and replaced them with these and it raised the car 2 inches?
I would keep the strut top under the metalwork otherwise you have all the weight of the car loading on 3 bolts.
Posted on: 2010/4/19 8:18
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Malaysia
Mine is juz B310 std strut. After replacing the std rubber top to pillowball it rises bout 2". At tat time,the gap between flare n tyre were like 120mm!!
I replaced the b310 std coil to b310 coil to cutted 1 1/2 coil n manage to lowered it bout approx 2". But is not stiff enough so i replace it wif the S14 rear coils n cutted it 1 1/2 round. Now i manage to lowered it to approx 80mm....
My current suspension spec
Reoiled Shock(stiffer)
Rear S14 Coil(Cutted 1 1/5 coil)
2" bump stop
Hi/lo Pillowball Mount
B310 Lower Arm set(retread caster rod + b210 sway bar)
Posted on: 2010/4/19 8:37
(1) 2 3 »
