2 ca's one with engine cooler one without?
From newcastle
as written before i have 2 ca's one has an enginr cooler mounted on the block where the filter screws on and one doesnt. tried to find some info on this but done no good.thinking of swapping the cooler setup to the engine without it (engine with cooler is shagged). does anyone run one of these engines without the cooler without any problems? will probably end up fitting the cooler for better reliability but was just curious.
Posted on: 2010/4/19 5:36
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
Re: 2 ca's one with engine cooler one without?
engine cooler? Do you mean oil cooler adapter?
Posted on: 2010/4/19 6:04
no cadet i have has one 2 im not sure wat it for ill take a pic
wheres pigdog when u need him
Posted on: 2010/4/19 12:31
Car free
From hastings,vic
de no cooler
det has a oil cooler( water to oil )
would run oil cooler cause thay dont hold much oil
and oil gets hot under boost conditions
Posted on: 2010/4/19 12:39
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
like this
det block and my 2 de blocks dont have it
jpg  19042010247.jpg (80.26 KB)
10308_4bcc41aeb8806.jpg 864X648 px
Posted on: 2010/4/19 12:43
Car free
