Browsing this Thread:
1 Anonymous Users
Help needed, gearbox pressure plate / mount |
I recently put a f4w60 into my 120y coupe and it feels like the clutch is not even there when i push the pedal it requires no force at all to engage the clutch?
The transmission is from a b310 but i think the pressure plate and clutch are from a b210 (f4w56a)
I also am having trouble mounting this gearbox as i cannot get it to mount properly with the 56a mount will i be needing the 60 crossmember for this or can it be done with an elongated 56a mount?
Posted on: 2010/4/20 6:36
Re: Help needed, gearbox pressure plate / mount |
Registered Users Contentmaster Usermaster
Yes, the mounts are different 60-series to 56-series.
The 56-series is for A12 -- and has a lightweight pressure plate. It takes very little force to engage the clutch.
The 60-series is for A14 -- with clutch plate with much heavier pedal effort.
Posted on: 2010/4/20 6:52
so will the 56 series pressure plate work with the 60 series box?
Posted on: 2010/4/20 7:19
Yes, the pressure plate (clutch cover) is same height. You can use either one.
There are two different release bearing sleeve lengths however. One used with engine plate between block and transmission, and a different length one for no-plate.
Posted on: 2010/4/20 7:37
