« 1 2 (3)
Re: Custom Head Shims [A-Series] - Who wants one? Submit Order ASAP
Leigh,
Pretty sure the chambers and everything are pretty similar to that of the GX head. I'll scan the H89 and overlay the shim drawing to check clearances. I'll probably open up the bores a bit as well, what sort of diameter would you prefer? 79mm, 80mm etc?
Keep in mind that the stock gasket on top of the head shim will probably measure about 3.5mm, otherwise order a smaller shim as well and double the two up? i.e 2 x 2mm shims to make 4mm.
Chris
Posted on: 2010/4/14 3:38
Bump, planning on ordering tomorrow. Any more takers?
Posted on: 2010/4/15 11:21
From SA
ill take a 3mm buddy is that still cool?
Posted on: 2010/4/15 13:52
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
No worries Danny boy.
Give me a buzz in the morning, we'll get those seat rails sorted.
Cheers.
Posted on: 2010/4/15 14:31
From NZ
How do you seal these? A head gasket each side?
Posted on: 2010/4/21 12:46
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
I intend to seal the gasket to the head using a compound suggested by Lemonhead.
Compound is "3M product is 'Threebond liquid gasket black' part no.(?) 1207B", I'm not after it specifically but something that does the same job.
Then I'll put a material gasket on the top or use the sealant again and put the head straight on.
Posted on: 2010/4/21 16:20
Guys the prices for the copper ones are GBP100 not Au$100 as I mentioned earlier, this was a priced by gasketstogo (pretty bad price really) I'll have a quick look around Adelaide for some better prices.
Damien S (DamienS)
Quantity: 2
Thickness/Guage: 2.5 & 3.0
Mike D (Dundee)
Quantity: 1
Leigh D (Lags)
Quantity: 1
Thickness/Guage: 3.0
Michael B (Budgiedagreat)
Quantity: 1
Thickness/Guage: ??
Dan G (Gylezy)
Quantity: 1
Thickness/Guage: 3mm
Simon P (Sikyne)
Quantity: 2
Thickness/Guage: 1.5, 2.00
Copper (MS instead?)
Posted on: 2010/4/24 16:33
Depending on whether the shims need to be milled flat after being laser cut, I may look into simply cutting 6mm thick shims that people can cut down to their preferred thicknesses.
Copper cannot be cut with a laser so I'm looking some alternatives, in the meantime though I do not see myself being able to supply copper shims.
I will arrange to get mine collected this week and I'll confirm whether they'll need surface milling or not.
Damien S (DamienS)
Quantity: 2
Mike D (Dundee)
Quantity: 1
Leigh D (Lags)
Quantity: 1
Quantity: 1
Thickness/Guage: ??
Dan G (Gylezy)
Quantity: 1
Greg V (Datsonovic)
Quantity: 3
Thickness/Guage: 1.5, 2.0, 3.0mm
Mike ?? (Cable_tie)
Quantity: 3
Thickness/Guage: 2.0, 2.5 (if available), 3.0mm
Posted on: 2010/4/25 4:56
Edited by clyons8 on 2010/4/25 6:26:29
Hello Guys,
This still going ahead.....all my money went toward a uni project
So things are delayed. But please, keep the inquiries coming.
Posted on: 2010/5/1 5:31
« 1 2 (3)
