HELP!!! no gas getting to the engine.
there is no gas getting to the engine, ive taken the fuel pump off and i tested it... it works fine! the fuel filter is fine, so it is something before that...
please i need help
Posted on: 2010/4/26 2:11
Re: HELP!!! no gas getting to the engine.
From Perth WA AUS
Blow some compressed air through the line, sounds like a blockage.
Posted on: 2010/4/26 2:32
Datsun 1200 2Dr sedan.
I had the same problem a week ago, the blockage was in the gas tank. i dropped the tank and cleaned it, it was full of rust and old gas which turned to a paste. first i cleaned it with acetone then muriatic acid(read how to use it first). i had to use 90 psi of compressed air to free the blockage in the pick up tube
good luck
Posted on: 2010/4/26 4:45
From mandurah
my car did this when i changed from an A12 to an A14 ,it turned out to be the filter had been tilted upright and all the crap inside it had covered up the hole on one end so i just by passed it and now it works fine :)
good luck !
Posted on: 2010/4/26 5:16
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Why didnt you just replace the filter Jesse?
Posted on: 2010/4/26 9:04
