SR20DET in a 120Y
From Perth W.A
is it legal in W.A?
how much to do most of it myself?
is it cheaper to source parts or get a half cut?
what brakes are a good conversion?
and i have been told that hilux diffs are really strong is that true and would a hilux diff take the punishment of a slighly worked SR20DET?
Posted on: 2003/11/13 6:53
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: SR20DET in a 120Y
From Brisbane
Hilux Diffs are extremely strong the axles are as strong as a 9 inch.
Posted on: 2003/11/14 2:06
From Perth W.A
thats good to hear any one else on the rest.
Posted on: 2003/11/14 3:17
120y Coupe
From sutho shire
90% sure its not aloud but 2 make sure check with your local engineer..
costs will be about installed in standard with computer and aftermarket computer will be about 6000$ pending on if u wanna change your diff brakes.. ect
hilux diff will hold any sr20det or ca18det from a fully bombed or standard motor as the axels are the same as a 9''diff would be a sweet ride witha sr20det wish i could of installed one in my ute! but ca18det is just as good as a sr20 if not better.
Posted on: 2003/11/14 22:25
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From sutho shire
brakes upgrade disc's and calipers
ive got venterlated disc 's with Girlock caliper.
just buy the motor box and wiring loom,radiator ..
save u money for other thing's that will be needed for the conversion..
hope this helps..
Posted on: 2003/11/14 22:29
Team New skool
Quite a regular
From Perth W.A
geez, that sounds like a real tight squeeze. grant from performanz in welshpool has that setup in his 120y drag car. have you seen it? he had to cut a big chunk of strut tower out to clear the turbo thats the size of a damn pumpkin!
Posted on: 2003/11/14 23:50
