Throttle opener question!
From Lisboa-Portugal
I changed the carburator of mine A14 and put it a A15 carb, the problem( or not!!) is that it doesn`t have that diaphragm of the throttle opener. Do i really need that because of the others emission control devices? there`s some disconected hoses but doesn`t seam to affect the engine work.
Posted on: 2010/4/27 11:19
Re: Throttle opener question!
From Sydney, Australia
Got a picture? Your question is not entirely clear in english.
Probably the words are technically correct, but not the right words for the carburetor parts.
Posted on: 2010/4/27 11:46
I can`t take pictures yet. But the thing`s missing in the A15 carb is this:
(the arrow in the bottom Throttle Opener Vacuum Motor)
Posted on: 2010/4/27 12:33
The Throttle Opener is not needed for any engine. It is for emission control, and no other parts depend on it.
Posted on: 2010/4/28 4:26
Yes the engine runs but is not as smooth as before.
Posted on: 2010/4/28 10:06
Two weeks ago I fitted a 1980 A14 carburetor to my 1972 A12, and it runs smooth again.
Posted on: 2010/4/29 7:02
From West of Seattle
I don't think it would be the fault of the exchange carb on your engine, as per say if it would match up or not. Probably your dealing with a 30 year old carb that would have to be rebuilt with a certain level of expertise and have it sleaved to have it run properly. If you find one that is in good shape and cared for properly, you may get a decent running engine - but it won't run as it had been intended to 30 years ago. If you desire a perfectly smooth and reliable engine you would need a new carb on top of an engine with strong but even comression and a good distributor.
Posted on: 2010/4/29 7:50
