Which wire goes where?
From Snohomish, WA USA
Thought I would throw this out there but if anyone has any info on the distributor for a Z24 motor, please fess up.
I need to install the wires and I need help on the connections.
The A14/A15 electronic distributor has a positive wire and a negative wire that goes to the black box on the distributor. The positive one is a White/Red strip and the negative is a White wire. The positive wire connects to the position that is marked (B) on the box. The negative is connected the the position that is mark (C).
The Z24 Distributor has (4) wires that go to it but it is also an (8) spark plug distributor. The Blue wire connect to (E). The Black/Yellow strip connects to (B). The White wire connects to (C) and the Red wire connects to (I). I am only going to use the primary plugs at this time so if it is as easy as it seems, I would only have to connect straight up to (B) and (C).
Help is needed.
Thanks.
Posted on: 2010/5/8 3:03
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: Which wire goes where?
ratsun will know...
Posted on: 2010/5/8 6:29
Dave. Send me ratsun's email. Thanks
Posted on: 2010/5/10 5:12
'73 2 Door Sedan
ratsun is a group forum: http://ratsun.net. Post your question there and I'm sure you get some useful replies. Maybe even some jokesters.
Posted on: 2010/5/20 18:57
