Problem with my daily
From Sydney NSW
My daily driver, a Honda Accord has developed a problem where it has a grinding, squeeling coming from the wheel. I had a look the other day and the CV boot was all torn up and grease was flung everywhere. Easy peasy I thought, replaced the CV and cleaned and repacked the inner joint while I was there. The noise is still there. I'm guessing bearing but its $260 for a new one, one side only (!). So before I go spending the money I was hoping someone else would have an idea, there being a lot of people in the know here.
The noise is intermittent, only comes on sometimes. It usually comes on with the application of the brakes, and will stay on when I release them but only a bit quieter, so now I suspect the brakes. I checked the pads and they're all good, plenty of meat. Anything else I could check?
Posted on: 2010/6/9 4:05
Re: Problem with my daily
From Sydney
Check your brakes again. Instead just looking at brake material look for an indicator, a little metal clip. Look for witness marks along the rotor and check that the metal brake cover is not touching the rotor.
Posted on: 2010/6/9 6:23
brakes usually squeal when the pads are worn and the disc is concentric meaning they might need machining but if it only does it when you brake i would say it would be the brakes
Posted on: 2010/6/9 8:41
datsun a15 ute
From Sydney NSW
Thanks for the help guys. It did turn out to be my brakes- but I had the wrong wheel. I could have sworn it was from the front, but I got my mate to stand outside while I drove past slowly, he said it was definately from the back. Lesson learned!
Posted on: 2010/6/10 9:45
