replacing R/H door window
Anyone know to replace the R/H door window? I have a replacement window ready to go in from the wreckers.
jpg  DSC00662b.jpg (107.13 KB)
13419_4c15a97d05ced.jpg 800X600 px
Posted on: 2010/6/14 5:01
Re: replacing R/H door window
Is tricky. Not difficult, but just remove the inner door panel, remove the glass stopper at bottom of door, unbolt regulator and roll it down.
If the original window is broken it should come out pretty easy
The tricky part is getting the new window in. Remove the wing so you have enough room.
Posted on: 2010/6/14 5:07
From Geelong, Vic
according to the workshop manual you are supposed to take the quarter window frame out, ive always done it this way and cant really see how the window would fit out otherwise
as you have to have the quater window frame out, sit new main window in the door, then place the quarter window frame back in and put the main window in the runners. then bolt the quater window frame in, then put the window reg in
Posted on: 2010/6/14 5:15
Sorry I should have called it 1/4 window instead of Wing.
Posted on: 2010/6/14 5:26
From Geelong, Vic
thought that was probably what you were talking about
Posted on: 2010/6/14 5:38
