« 1 2 (3)
Re: Installing Thermostat
From Perth WA AUS
As for the gurgle sound: do you have a coolant return resevoir? that can make that sound and is normal.
Posted on: 2010/6/14 10:28
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi Levey
I don't have reserve tank in mine,it sound like Air in the cooling system (that is a common problem as i have searched from other forums) the solution is to re flush you cooling system and refill it again..do you think the gauge indication in yellow (in the above pic) is too hot ?
have you any one ever experiences driving for this much of higher engine temp ?
Thanks
regards
sumith
Posted on: 2010/6/14 11:04
From Perth WA AUS
Maybe your radiator cap has a too high pressure rating and is not releasing the excess pressure?
Posted on: 2010/6/14 11:31
From Sri Lanka
Hi Levey
Good Point Actualy I am not having Original Radiator Cap, this is from some other vehicle, i can't remember what model was it ?
What is the PSI rate for Datsun 1200 standard is it 15 or 17 ?
thanks
regards
sumith
Posted on: 2010/6/14 11:48
From Perth WA AUS
I'm not sure I will check.
Posted on: 2010/6/14 11:51
From Perth WA AUS
12.8psi according to the manual.
Posted on: 2010/6/14 11:56
Sumith, I have theory. The gurgle was the system air-bleeding itself.
This happens often after changing the thermostat, and causes it to run hot. So now let it cool down, top up the radiator with more coolant, and it should be good.
Posted on: 2010/6/14 17:28
« 1 2 (3)
