« 1 (2)
Re: AUDI 50 CLUTCH INTO 63A GEARBOX??
From Geelong, Vic
yeah why would the small L series clutches not be your first choice?
Posted on: 2010/6/15 11:17
From Lisboa-Portugal
It is now...:)
Posted on: 2010/6/15 11:58
From Perth
But the spline size and diameter are nothing like the A series
So an L clutch isn't much good to you either
I'm not sure whats trying to be achieved
Posted on: 2010/6/15 13:12
the L14 engine is..
Posted on: 2010/6/15 14:19
A-series engines don't have splines.
The 63A 5-speed for A-series engine uses the same input shaft diameter and splines as 63A 5-speed for L-series engine. So you need the same clutch disk as fitted to the L14 engine. It is 180 mm diameter and so takes a standard A14/A15 clutch pressure plate.
Or you can redrill the A12 flywheel to fit the more common L16 clutch disc and pressure plate (200 mm diameter)
Posted on: 2010/6/15 17:15
I found one cheaper and more available, the 140j violet(j710) clutch.
Congratulations. That should be the L14 engine with 63-series 4-speed or 5-speed. Most had 4-speeds.
Posted on: 2010/6/16 5:35
« 1 (2)
