(1) 2 3 »
Did the 1000's have seat belts?
From Brisbane
My B10 doesnt have seat belts at the moment, but i seem to believe that it may have at some stage ... There is a bolt on the pillars that looks like it can only be for seat belts, but i cant see any on either side of the seat (but i havn't looked properly ... Did they come with seat belts? If so how hard are they to find?
Posted on: 2010/6/17 15:32
Re: Did the 1000's have seat belts?
Pre 69 no 69 -71 fronts only after that all seats must have seat belts
Posted on: 2010/6/17 15:38
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
From mandurah
you should be able to get them new or get a set made if you could get a sample or the sizes
Posted on: 2010/6/17 15:39
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Brisbane
Its a 67 or 68, so ill go with no ...
I wouldn't mind having a set, Everytime i get in i reach for them and get worried, too used to having them ...
Any suggestions where i can get some?
Posted on: 2010/6/17 15:41
If u have fitted a seat belt u must use it all the time
Posted on: 2010/6/17 15:43
1200 ute stocko
XR8 tow car / daily
bailz is orsum
From mandurah
pppffft
there should be someone wrecking one somewhere ?
Posted on: 2010/6/17 15:47
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Brisbane
Yeah i realise that, I dont mind using it at all ... Its just that i've been wearing one for the last 25 years so its kind of a habit ...
Posted on: 2010/6/17 15:48
From Perth
ALl the ones I've owned did
Even if they were just lappys
66 67 68 69
Usually not in the back though
Posted on: 2010/6/17 16:17
From Brisbane
I would assume this one did too at some stage ... Unless they came out with mountings on the pillars but no belts ...
Did those lappys have mountings on the floor?
Posted on: 2010/6/17 16:25
From Canada, B.C , Richmond
Yes, they are mounted on the floor next to the seat. There are two bolts/holes where it used to go. If you go to Lordco, you can pick up lap belts that look almost like the 1000 oem ones.
Posted on: 2010/6/17 19:10
(1) 2 3 »
