cant get my oil filter off!!!
From Canberra, ACT
cant get my oil filter of i have tried but have ended up putting a hole in the side of it its on my datsun a12.. whats the best way of taking it out when its really tight
Posted on: 2010/6/18 7:34
Re: cant get my oil filter off!!!
if you have already tryed a oil filter removing tool and it didn't work.
hit a big screw driver right though it and them leaver on the handle.
Posted on: 2010/6/18 7:42
From Canberra, ACT
ill try that tomorrow things you learn everyday thanks for that
Posted on: 2010/6/18 8:11
From Sri Lanka
Hi budgiedagreat
Actually i learned this from my Father, that time i did not have oil filter removing tool and it was very tight, what he did was took a strong thread and a strong screw driver and surrounded the filter with thread and buckled the screw inside the thread and turned it tightly
no harm to filter at all
thanks
Regards
sumith
Posted on: 2010/6/18 8:43
i usually get a new oil filter and skewer through the old filter with a flat end screw driver and twist it of(unscrew it) then just dont do the new one up as tight.
Posted on: 2010/6/18 12:26
From SE Melbourne
Those oil filter tools should get anything off! The 3 legged ones are the best
Posted on: 2010/6/18 13:14
Mildman, Datsunless
To prevent this from happening again:
* Put a thin coat of new oil on the new oil filter O-ring
* Tighten only by hand. Newer use a tool to tighten an oil filter. Tighten no more than the instructions (usually 3/4 turn after seal contacts the block). Usually you cannot tighten it this much by hand.
Posted on: 2010/6/18 21:41
From Canberra, ACT
its the origanal filter so its pretty old and i know how too change an oil filter just this one is being anal
Posted on: 2010/6/19 2:51
Change the entire pump if it's stuck on there. They're cheap as to get.
Posted on: 2010/6/19 3:08
From Canberra, ACT
na my dad had the same problem on his ducati he knows how to take it off u gotta drill a hole sumwhere and it releives the pressure around something he will show me how too do it tomoz
Posted on: 2010/6/19 5:14
