It was Faulty Thermostat
From Sri Lanka
Hi Guys
Just wanted to flush my cooling system and took the radiator hoses etc and wanted to recheck my thermostat also, Checked it but now it doesn't work so that is the problem , Can a NISSAN Genuine thermostat can be faulty within 1 or 2 days like this i am frustrated on this, i am gonna to call dealer and ask for replacement,since this country is bit warm 28-32 Celsius,do i need to go for 76.5 C or 82 C thermostat , what do you guys think about ?
Thanks
Regards
sumith
Posted on: 2010/6/16 4:31
Re: It was Faulty Thermostat
Yes,they can go bad right away. But be sure it goes in all the way without hitting the back of the casting. I measured a head, and that D21 thermostat may be at the limit of space. Tightening the bolts may bend it.
* 82C/180F thermostat is best for the engine
* 88C thermostat is used if you want the room heater to be hotter
* For maximum fuel economy with the stock engine, use the manufacturer specification, which for Japan B210 is 82C
Optional for "tropical use" is the 76.5C. I suspect this is to keep the room heater less hot. Or maybe there is another reason.
The radiator is more efficient at hotter temps.
Posted on: 2010/6/16 4:47
From Sri Lanka
Hi Guys
i am waiting to get another thermostat from dealer as they are not in stock at the moment,have to wait few days for it
meanwhile can i fill my cooling system with auto flush
and clean the system without thermostat ?
thanks
Regards
sumith
Posted on: 2010/6/16 9:25
Yes
Posted on: 2010/6/17 0:17
From Sri Lanka
Hi Guys
Did a cooling System flush nicely,
awaiting for the Thermostat to come
at the moment running without it, engine is too cold now than earlier, it it rains sometime you don't see temp gauge working also , system is too cold it maximum rins to Red Line as above pic
Thanks
Regards
sumith
jpg  Temp.JPG (9.67 KB)
10994_4c1eea22c8b20.jpg 352X288 px
Posted on: 2010/6/21 5:27
