Thermostat Opening Messurement
From Sri Lanka
Hi Guys
Has any one checked the Measurement of Thermostat opening
distance , is it differ from 82 to 76.5 C or all the thermostat open the same measurement, i felt my new thermostat opens bit lesser than earlier defective one .
thanks
Regards
sumith
Posted on: 2010/6/23 6:01
Re: Thermostat Opening Messurement
The different models open different amounts.
The B110/B210 one opens only 8mm. See details at http://datsun1200.com/modules/mediawi ... mostat#Thermostat_Testing
Posted on: 2010/6/23 6:13
From Melbourne, Australia
some open at different tempratures, i think 73 degrees celcius and 78 is available usually. they should open the same amount though when open
best way to test is to put it in a mug with boiling water from the kettle and watch it open
Posted on: 2010/6/23 6:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sri Lanka
Hi dd
Thanks, then that is ok i remember it is also opening around 7 to 8 mm
Hi 1200rallycar
Thanks, yes i am boiling it over a period of 4 5 days and see its response,then if i am satisfied with it i will install it to the car,because had a horrible time with previous Thermostat.
Thanks
Regards
sumith
Posted on: 2010/6/23 6:17
The D21 thermostat may need to open more -- it's a lot longer.
Did you bleed the coolant system after replacing the thermostat? If not, it is likely to overheat.
Posted on: 2010/6/23 6:37
From Sri Lanka
Hi dd
here the story
http://datsun1200.com/modules/newbb/v ... hp?topic_id=46344&forum=1
i got different thermostat now that is i think Nissan Petrol Y60 76.5 C
yes i have re flushed the cooling system too..but did not install new thermostat
at the moment i am bench testing it for few days , then install it on the week end if this doesn't work fine i will give up thermostat.
Thanks
regards
sumith
Posted on: 2010/6/23 6:46
yes, you flushed it. But did you bleed the cooling system after re-filling?
Also, did you check that the D21/Patrol thermostat freely fit? I measured a head and it seems like that thermostat will hit the back of the casting?
Posted on: 2010/6/23 7:33
From Sri Lanka
Hi dd
Actually u can fit it it doesn't hit Casting , yes i will make sure to bleed the system
Thanks
Regards
Sumith
Posted on: 2010/6/23 8:01
From Sri Lanka
Hi Guys
Checked the Thermostat again actually it is opening 10MM exactly,but not sure whether it is starting exactly on 76.5
thanks
regards
sumith
Posted on: 2010/6/24 5:08
