need help with the front of my ute
From Bendigo Vic
Heyi just got new radius rods and they wont fit no my ute, it's like they are 2 long,
i dont no wat is wrong with them will it be my ute or did the different radius rod for different year?
jpg  DATSUN RODS.jpg (113.68 KB)
10708_4c23194742a7d.jpg 1024X768 px
Posted on: 2010/6/24 9:37
Re: need help with the front of my ute
From Bendigo Vic
the one i got off ivan is the some as the new ones but see were the thread is long on my rod?
Posted on: 2010/6/24 9:40
yours looks modded, ive never seen ones with a nut welded on the rod so yours may be rethreaded
Posted on: 2010/6/24 12:08
From Ringwood, Melbourne, AUS
Yep, bottom one looks like a standard one and the top has been modded for more +ve castor.
Posted on: 2010/6/24 12:18
Deano
From Melbourne AUS
hey aido you can still use them, you'll have to use a nut/washer on either side and adjust
the amount of castor you want (a good thing)
if you really want original rods i can swap you some if you like
Posted on: 2010/6/24 12:32
1973 B110 A12
From Bendigo Vic
i got new bottem arm ( stanza lower control arms) and i cant get the radius rod to fit, it is a sunny radius rod and is the same as the standard one.
it feels like i have 2 push the bottem arm back far and still cant get the bolts to line up? i dont no if it is the front of my ute is up the #OOPS# but both side are the same or something im doing wrong?
Posted on: 2010/6/25 7:34
Edited by aido on 2010/6/25 13:33:26
From Bendigo Vic
has anyone had this problem before?
Posted on: 2010/6/25 13:37
YES. You have a mix-and-match set of parts.
* Datsun 1200 ute
* with non-1200 LCA
You need a radius rod (Tension Rod) that bolts to the Stanza LCA, and also will bolt to the tension rod bracket at the front of the 1200
Posted on: 2010/6/25 22:23
