« 1 2 3 (4)
Re: datsun 1200 13b turbo project
From brisbane. waking up the neighbours with the brap
the diff was staying with the car.the car has sold.
my mate has a set of r31 struts and brakes with adjustable strut tops for sale. he has advertised them in classifieds. they work well as i was using them in my car before i got this setup. they can be ford 5 stud or datsun 4 stud. he will set them up for you.
as for the gearbox use either series 5 or supra. make a new x member that bolts to the floor and chassis rail. nice and easy. if it was a series 4 box id sell you the x memeber i have at home.
Posted on: 2010/5/4 23:05
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
Quite a regular
From perth
yer i use series 5 turbo gearbox. just getn my hilux diff shorten now yer im pretty keen on those brakes and that ill try pm him
Posted on: 2010/5/5 8:13
From Sydney
what made you go series 5 and not a old rotory? and whats the difference in gearbox crossmembers between s4 s5 i would still be keeen if it fits a 1st gen gearbox 5speed from a rx4?
Posted on: 2010/5/5 9:51
From Sydney
how hard of a job is changing the 13b series 5 engine to a 12a timing cover? and i heard you can leave the top mount as it fits with the bonnet closed? is that true.. so whats involved in the conversion?
12a timing cover
custom top mount turbo
tailsharft
remove the air pump.
Posted on: 2010/5/5 9:57
Quite a regular
From perth
i had a rx7 series 1 with s4 engine and s5 gearbox. so im just transfer everything over. the engine mounts were on the front so i change them 2 the normal mounts on a 13b(change sump and that). then yer the maddat kit fitted perfect. just the gearbox mount in the kit and changed a bit ill get a few pics 2moro of it. and i dont no 2 much about changing the 12a timing cover and that. if u need pics let me no datto13b thats 1 thing i wish i had:)
Posted on: 2010/5/5 11:35
Edited by jonesy989 on 2010/5/5 13:59:28
series 4 and 5 gearbox brackets are different. series 4/5 box are pretty strong. a series 1 box wont last long if u drive it hard.
as for the 12a timing cover. get a rotor shop to do it because there is some seals you can damage in the changeover. the thing is you need to change ur sump then to an rx4 sump if you go `12a timing cover.
i think the mad dat kit is a good way to go. saves you buying a 12a timing cover, sump and getting someone to change the front cover over. then you have to make engine mounts and bracketts.
datto 13b i pm'd you my number. if you give me a call il give you the run down
if i was to fit another 13b to a 1200 id use the mad dat kit.
Posted on: 2010/5/10 5:13
www.maddat.com.au
From Sydney
thanks for the info guys.. im thinking of the maddat kit but still unsure.. but im considering s5 13bt with 12a timing cover and rx4 sump
Posted on: 2010/5/11 10:48
looks nice mate! well done!
Posted on: 2010/6/30 4:57
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
hows the project going mate. i finally put some pics up of my car. have a look and tell me what you think
Posted on: 2010/6/30 5:09
www.maddat.com.au
From Sydney
looks neat.. im getting my 13b enginnered with a T04 next week, its looking good so far i will keep you guys up to date...
Posted on: 2010/7/2 12:34
« 1 2 3 (4)
