« 1 2 (3)
Re: Mods needed for Sunny A12
From Brisbane
I want to do the A14 conversion but difficult to look for the engine and more $$$ involved, i was just thinking doing the conversion early next year after this expensive christmas holiday.
So for now I want to put a new carby on my A12
which escorts and cortinas have 32/36 weber with manual choke?
Posted on: 2003/12/3 20:50
From Brisbane
I found an A14 engine with twin SU carby with extractors dont know the price yet...
What sort of price can I get these package?
What else do I need if I go ahead with this conversion?
A14 engine + new gearbox?
or can I use my existing stock gearbox for now?
Please advise as the guy selling it just called me.
Posted on: 2003/12/4 1:35
From Brisbane
Do you need an engineer's certificate for A12 to A14 conversion on 81 Sunny?
Posted on: 2003/12/9 0:51
From Perth, Australia
I shouldn't think so as you're only increasing the cubic capacity of the motor by a relatively small amount and there isn't a great deal of engineering involved... However Things may vary from State to State so the best thing is to go to your Licensing Department and get the right advice from them. Hope this helps
Posted on: 2003/12/9 3:10
From Canberra, Australia
standard gearbox should be fine.
I'm still using my 1200 one, and I think Sunny ones are even stronger (Althoguh not sure)
So you should be fine.
With engineering.
It's best to check with your rego place.
But I shouldn't think it would be a problem.
Some sunny's had an A15 in them from the factory. I don't think that they had any brake upgrades or anything like that. So you should be fine I think.
How much is the A14 gonna be?
Posted on: 2003/12/9 3:21
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Brisbane
I'm still looking for A14
I found one but he wants $500 for A14 with twin SU + extractors
I think thats expensive
not sure about the labour yet as I cant do it myself dont know that much yet...
there's an A15 at the local wreckers for $500 + $350 for fitting it but thats for straight fit only if I put A15 It needs a few modifications on mountings so more $$$
Posted on: 2003/12/9 3:27
Not too shy to talk
From Darwin, NT
how bigger ET time difference is the A12 with the A14, both with weber and extractors....my mate was gonna change over and wanted to know if he should go the A14 or A15??? i told him the A14 revs harder....right>>>??
Posted on: 2003/12/11 5:25
From Brisbane
Can I just buy any A14 engine for my 81 Sunny Automatic, will the manual version fit in regards to transmission tunnel and that?
Posted on: 2003/12/11 23:09
« 1 2 (3)
