Datsun 200B engine compatibility
From Ballarat, VIC
Ive got a 1978 200B with a badly warped head gasket lying around, im thinking it needs a new engine. I was was thinking of finding another 200B engine but am wondering what else would be compatible/ recommended for the 200B. a friend of mine has a 1987 nissan pulsar hanging around with low k's, would the motor from it slot in and be powerful enough for the 200B? I'm not particularly mechanically minded so for all I know I may be way off here, and any advice would be appreciated
Thanks
Posted on: 2010/7/4 13:32
Re: Datsun 200B engine compatibility
get another l20- depending where you are but shpould be easy enough to get one
Posted on: 2010/7/4 13:44
L20 might be a difficult fit. Get a four-cylinder like the original, or an SR20DET.
Posted on: 2010/7/4 21:49
From Nyngan, nsw Australia
L20B is the original 4cyl here in aust.....there DD
Posted on: 2010/7/4 22:55
living is good,.....
Yes, same here for the later 610. Unfamiliar mentioned the L20 which is a six-cylinder engine.
I have seen 610s with FJ engine, but I reckon an SR20 is a lot lighter.
Posted on: 2010/7/5 0:13
From Geelong, Vic
yeah apparently SRs bolt straight to the stock 200b crossmember. but for someone not particularly mechanically minded another L20b would be the way to go
Z series also bolt in, Z18, Z20, Z22, Z24 so they would be the simplest non stock conversion
Posted on: 2010/7/5 1:02
L20 is also a 4 cyl engine
Posted on: 2010/7/5 2:32
Sorry mate but the L20 is a six cylinder engine. When the 4 cylinder L series engine was produced in a nominal 2 litre size [1952cc] years later, they added the 'B' to differentiate it from the six cylinder version so that nobody would get it wrong.
L20 = six cylinder
L20B = four cylinder
Posted on: 2010/7/5 2:37
Love your Datsun.
Treat it well.
Unfamilia I thought you knew something about Datsun engines.
From Ballarat, VIC
Thanks all. sounds like i should be going for an L20B engine then. will the L20 6 cylinder engine slot in as easily as the 4 cyl? Because i would get a V6 engine for it if it wont be too much of a hassle, just for a bit of extra power...
Posted on: 2010/7/5 2:50
