« 1 2 3 (4)
Re: Datsun A series turbo manifolds -- register interest
From New Zealand
I agree with you D.. there is room for a little improvement! Would be worth the effort. I build headers and turbo manifolds for a living.. and I for one know that they are not always an easy task.. Good on ya for givin it a go mate! I know lots of people that dont have the balls to pick up a welder and grinder and get stuck into it!! good on ya! nice ute by the way
Posted on: 2010/7/7 9:51
From Sydney NSW
definately interested, just need a few more details on 1000's fitment and price
Posted on: 2010/7/7 13:53
I just want to help not step on anyones toes and I can only thank what Sikyne and Jmac with
Simons handy work making manifolds for me and others at his workshop really hitting home.
Just using a separator will make that a T intersection like hitting a wall dead on.
Turbulence will reduce efficiency overall more than 5-10 per cent claimed to around 25%.
With a little rotation and grinding off the 1 and 4 bends the 1 and 4 collection points
meeting the flange will be more angled relieving the T instersection effect.
The other option is the true and tried TOPGEAR manifold which is the ultimate and very little use of material also but ultimate flow.
When I say True is that from 33hp at wheel it improved to 128hp almost 4 times improvement.
Even that manifold could be improved if you look at the picture
A.
types of bends in blue circles can be 1.2,3 and 4 (1 is square, 2,3 bends and 4 straight pipe)
B.
The white arrows are where you can rotate 2 and 3 bends down at that point then number 4
can be a straight pipe and also allow more inlet manifold clearance (indicated in green).
Pieces total excluding flanges: 4 square, 4 bends and 2 straight.
jpg  topgear.jpg (87.40 KB)
737_4c3530785a63c.jpg 1000X638 px
Posted on: 2010/7/8 2:57
From Sydney NSW
Any news on these? Cheers
Posted on: 2010/8/2 3:44
From SA
yes,
sorry about the major delays, iv been getting smashed with school and trade school and what ever else.
just to make sure everyone is aware the manifolds will fit with a standard inlet manifoldbut im now back at school so i have a fair bit of spare time on computers.
i am going to be redesigning and making two different manifolds only because of the interest i have has so far with the first design. The first manifold does have a divider between the collector,the way it was fabricated is with a weebbing in the middle joining the two pipes to the diameter of the t25 flange. (will provide pics)
i am also going to be making some up with all 4 pipes meeting at the collector as D has suggested although these will be of higher expence as there is more fabricating and time required (price yet to be confirmed)
just waiting on the pressure pipe bends so fabrication will begin as soon a possible
1000 manifolds will be on the way very soon have already sorted out a design and it will be similar to a top mount.
thanx Dan
Posted on: 2010/8/2 4:19
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
« 1 2 3 (4)
