Brake Problem ?
From Sri Lanka
Hi Guys
I feel there is no proper brake in my car when i pedal it first time, but when i pedal it second time then after i get the normal brake,is it a air in the system ? or any other problem
thanks
Regards
sumith
Posted on: 2010/7/16 7:03
Re: Break Problem ?
For this type of Brake System problem, there are three likely causes:
A. Drum brakes need adjusting
B. air in the system
C. an internal leak in the master cylinder (worn out)
First perform Brake Adjustment. This needs to be done about once per year.
Posted on: 2010/7/16 7:12
Re: Break Problem ?
From Pretoria SA
Yeh bracks nead to be bleaded throu every year (especialy older cars)
I had a prob with my old 1200 sadan, for some reason it had water in the pipes(no leaks), it had the same simtoms Quote:
I changed all the seals, used new brackfluid and fluched the hole sistem
My prob was solfed
Posted on: 2010/7/16 7:24
1400 Turbo
Re: Brake Problem ?
Quite a regular
From melbourne
i had a leak, which filled the left front drum brake with fluid. new mastercylinder was sooo cheap for a new one
Posted on: 2010/7/16 8:53
