« 1 (2) 3 4 »
Re: is there any suspension upgrades for 1000's?
From Perth
Numbers again please Mike
Posted on: 2010/6/2 14:27
From Freo
F/R Description Part # Kits
Req Bushes in Pack Key Service Alignment Notes
F Control arm - lower inner 45134 1 4
F Steering - idler bush 41001 1 2
F Strut bar - to chassis 48088 1 4
F Sway bar - link 42080 1 8 Suits B120 models
F Sway bar - link 42010 1 8 Suits B110 models
F Sway bar - link washers 42933 1 8 Cupped washers only no bushes
R Shock absorber - upper & lower 43020 2 4
R Spring - eye front 47155 1 4
R Spring - eye rear 47156 1 4
R Spring - shackle 47157 1 4
Posted on: 2010/6/2 14:33
A15 PSI Project Motor
'72 CB750k,
From Freo
I've got packets in the shed of the bushes i used in the 1000...
Posted on: 2010/6/2 14:34
'72 CB750k,
How hard can it be to make them if you had access to a lathe?
I remember working with this stuff called Delrin at uni, it was cheap as to buy and machined beautifully, have heard you can use it to make bushes?
From Adelaide, Australia
are all those numbers for just a 1000?
Posted on: 2010/6/2 14:37
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Perth
Lower inner
Its a 1 piece steel outer bush... sure your number is right ?
Or are you using them in an upper situation and you don't have a lower ?
Either way... one is missing off your list
Posted on: 2010/6/2 15:08
From Wagga Wagga, NSW
Whats our options in the front swaybar department ?
Posted on: 2010/6/2 23:52
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Hey Dundee or anyone, do you have the part number for the leaf spring rest rubbers...yknow the ones that are NOT bump stops but everyone calls them that, yknow the ones you cut for lowering.
Are they still available?
I want to lower my front a bit but would like to have the option of returning to stock should my imminent return to the apple isle require some more clearance ;)
Posted on: 2010/7/17 4:24
are these numbers from repco?
Posted on: 2010/7/17 4:46
yea ive been wondering that.
Posted on: 2010/7/17 6:38
« 1 (2) 3 4 »
