(1) 2 3 4 »
Datsun Mechanic's List
Is there a list on this forum of known Datsun mechanics, People that live, eat, breath them ?
If not could I have some names/locations of known D-mech's pretty please ?
Thankyou
Lowmion
So that's
Jason Thompson
c/o-
Tomoz
Hastings Vic
ph 0411797234
Posted on: 2010/7/18 10:14
Edited by Lowmion on 2010/7/18 10:56:23
Luck is what happens when Preparation meets Opportunity.....
Re: Datsun Mechanic's List
From Brisbane
Posted on: 2010/7/18 10:25
Is there anyone else recommended? or just one guy in Hastings Vic?
Posted on: 2010/7/18 10:57
so everyone does their own work? no datsun mechanics known to anyyone?
Posted on: 2010/7/19 1:09
Yep. Pick up a spanner and get to work!
BigE in NSW is definitely one of the best.
Posted on: 2010/7/19 1:19
damn - I need an opinion on what the hecks wrong with mine, don't want to buy a replacement engine just to find out a decent set of carbies would have done the job, or visa versa
Posted on: 2010/7/19 2:25
Well write-up your issue in the main forum and see what advice you get. There is a pretty high chance that someone has had the same problem/s that you are encountering.
Be sure to give a good explanation of what you have and what the symptoms are also include pics or videos and that helps.
Or write what your problem is on this thread?
Posted on: 2010/7/19 2:47
ok, I have an undetermined air leak, causing car to only run with choke on, and badly. there's no water in my oil (no milk) and i put new gaskets in the carbie, reset the float, cleaned the jets, etc etc, i can't see any cracks in the manifolds, nore on the head/block, and she's not running hot.. so wanted a trustworthy mech to pressure test cylinders, and wd40 leak test manifolds carby hence wanting to know where you lot took yout cars
Posted on: 2010/7/19 6:31
Have you tried another carb/manifold altogether?
Work on eliminating all the variables, clean fuel, timing good etc etc.
You could spray aerostart round the manifold flange and see if the engine note changes (be careful).
Posted on: 2010/7/19 6:52
give tomo a call. but the aero start will also show if there is a leak, not onto a hot exhaust though
Posted on: 2010/7/19 8:24
(1) 2 3 4 »
