(1) 2 3 4 »
H145 Housing / H150 Centre - Spacer Shim for Diff Centre Upgrade
Sorry to have these threads through the forum but they’ll be gone before long.
It looks like there was some interest in the spacer shims when I mentioned them in the other thread.
You can replace the H145 diff centre with a stronger H150 diff centre but in doing so you tend to be left with a rather large gap between diff centre face and diff housing face. Instead of over doing it with several gaskets you can use a steel shim.
I am trying to get some cut with the manifold flange order as well as having the material sheet gaskets to go with each shim (2 gaskets per shim). So far the interest is as follows;
Looking at around AUD$25.00 depending on numbers. That's a rough figure.
H145 Housing/H150 Centre - Spacer Shim 2mm Mild Steel
elemental_funk
D
edp
ang94541
clyons8
Posted on: 2010/7/22 4:14
Re: H145 Housing / H150 Centre - Spacer Shim for Diff Centre Upgrade
elemental_funk
D
edp
ang94541
clyons8
cable_tie
Posted on: 2010/7/22 8:49
At anyone wanting one of these - BUY IT.
At 25 bucks Chris has got a real bargain here for you - look at the second option!
http://cgi.ebay.com.au/H150-Conversio ... ories&hash=item3a599565ae
Posted on: 2010/7/22 10:36
107aud delivered is not an option guys so help chris out with a little loose
change for all his efforts and never look back.
Chris you should also go to Ratsun.com just in case there are some still using
the H145 in old cars. The other option is Malaysia as there are several 1000s
running around. There should be 2 canadian 1000 owners that will need them.
Posted on: 2010/7/22 10:44
From Perth
I asked about these too
I'm doing the swap tomorrow... but can out the shim in later if need be
Posted on: 2010/7/22 11:09
Neil what you doing for the extra space? extra gaskets?
these shims are awesome for the price.
Your race car I thought would have had the h150 already happening
that race thing must be light.
Posted on: 2010/7/22 13:03
Thanks for the comments. I'm having trouble trying to find thin gasket sheet. The people I'm dealing with don't do this sort of work either (cutting material, they only do metals) so it'll have to go to someone else.
elemental_funk
D
edp
ang94541
clyons8
cable_tie
dattoman_1000
Posted on: 2010/7/22 13:55
From Perth
I sold my racecar 3 yrs ago
Its in Melbourne now
I'm just going to "make it fit" for now
I have too... I can't stand the noises coming from my diff/gearbox any longer
So the cars getting a birthday... swap box , clutch , wheel brgs and centre
Did you get a spare glass for the wagon?
Posted on: 2010/7/22 13:56
Back in Melb, funny dat anyone here?
Posted on: 2010/7/22 14:19
(1) 2 3 4 »
