Will this tachometer work? Or have I bought a dud?
I bought this today, thought it was particularly cool as it was so small and of the sort of style that would suit my 1000.
One question, the needle sits a little higher than it should, is this a fault? Will it return to where it should once it's 'on' Or have I bought a dud?
Or is it a matter of adjusting it? I didn't notice it when I bought it.
Any advice on the co-coordinating of the wires would be appreciated too.
jpg  Tacho.JPG (121.67 KB)
7952_4c4be41b5d5d0.jpg 1095X821 px
Posted on: 2010/7/25 8:13
Re: Will this tachometer work? Or have I bought a dud?
Hard to say. Some will read correctly when operating, but some would be off that amount.
what are the colors of the wires? Red or Blue is usually the tach signal (neg terminal of coil) and black is earth/ground. Blue might be the lamp is there is a red wire, but if not then yellow.
Posted on: 2010/7/25 8:39
From Sydney
Even if it is broken, it should be a relative easy fix. Do you have any instrument repairers in your locale. Yours appear to be a mechanical fault rather than an electrical one. A balance and calibration should see it just right. I use a repairer local to me, and they do excellent work.
Posted on: 2010/7/25 8:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Not too shy to talk
From Wagga Wagga, NSW
Black:Earth
Red:+ Coil
Green:- Coil
White: Parkers
Posted on: 2010/7/25 9:00
Why Drive? When you can drift.
Thanks very much guys. Awesome!
I'll give it a go and see how it works, I had a look at it and it looks like it has been opened up before so I reckon it might have a problem. But the old dude insisted it worked well. I'll wire it up and see how it goes.
Made in Japan too by the way!
Posted on: 2010/7/25 9:13
