t25 turbo water/oil line setup info needed
i neeed to know how to go about turning the oil line down on my t25.
ie do i unbolt the 4 bolts to the cast housing and undo the c clip on the turbo and turn?? will i need to rebuild it if i do this or can someone help out with info on how to do it. i need the oil return to face down as u will be able to see in the pic its not down. thanks nick
jpg  Image001.jpg (118.04 KB)
10308_4c4fef388f0b3.jpg 480X640 px
Posted on: 2010/7/28 9:47
Edited by supafatto on 2010/7/29 14:19:39
Edited by supafatto on 2010/7/30 9:26:30
Car free
Re: t25 turbo info needed
From Brisbane
yes mate, undo the four bolts that bolt the centre onto the ex housing and rotate 90 degrees, i would remove the actuator and undo the circlip and then rotate comp housing to suit the actuator or your piping, you wont need to rebuild it, seals are in the centre housing.
Posted on: 2010/7/28 11:40
AWD the way to go
thanks for the info :P
Posted on: 2010/7/28 14:06
Car free
and then clean that garage ;)
Posted on: 2010/7/29 4:54
need help on how people have setup oil and water lines and some pics as the a14 is bsp tread and the t25 is metric i think
Posted on: 2010/7/29 13:19
Car free
From Geelong, Vic
CA have the same thread in the block line i said, and they have an L shaped adaptor that the solid line screws into...kinda like a large brake line fitting
you have plenty of CAs, have a look at them
Posted on: 2010/7/29 13:54
i have the lines fitted to the turbo but not to a series as a series is bsp and the braided lines i have are metris
Posted on: 2010/7/29 13:57
Car free
