Is this Too Advance or Too Retard ?
From Sri Lanka
Hi Guys
I feel when the engine is cold it doesn't start at once it turns the engine and stops suddenly like weak battery then again it cranks and start the engine.
i know it something with Distributor settings is it too advance or too retard ? what would your guys suggest ?
thanks
Regards
sumith
Posted on: 2010/8/2 4:36
Re: Is this Too Advance or Too Retard ?
From Canada, B.C , Richmond
If it was too advanced, you would hear it ping pretty bad, right?
Posted on: 2010/8/2 4:41
From sydney
Check it with a timming light
Posted on: 2010/8/2 6:23
From Sri Lanka
Hi subwoffers
Pinging of valve also there a bit more than earlier
thanks
Regards
sumith
Posted on: 2010/8/2 6:57
From Malaysia
i think it is too advanced. retard it a bit.
Posted on: 2010/8/2 7:25
rotate the distributor 2mm counterclockwise and see if it runs better.
Posted on: 2010/8/2 8:39
From Malaysia
if it is too advanced, retarding it would be easier to start, and the idle will be smoother. no more 'boiling' sound from the exhaust.
Posted on: 2010/8/2 8:50
