Tunnel Question
Quite a regular
From Canberra
Hey all, Rounding up parts to get the ute on its way and i was just reading the tech wiki regarding tunnel swaps i have a 1200 ute that i'm putting a ca in. I've seen the maddat ones, but would prefer to be able to run the heater box, so i was thinking about using a 120y tunnel. should i use a manual or an auto tunnel??
is there other tunnels i should be considering??
Posted on: 2010/8/24 4:50
Re: Tunnel Question
From Geelong, Vic
both auto and manual 120y tunnels are the same. there is a difference in the floor pan between early and late ones but i dont think that affects the tunnel
120y is by far the easiest tunnel swap apart from 1200 auto tunnel
if you cant find 120y, 180b and 200b ones are pretty much the same size. just a little more work is required to get the back to match up
my first tunnel job, 180b
second one with 120y
Posted on: 2010/8/24 5:06
Re: Tunnel Question
Will the B110's factory heater fit when a B210 tunnel is swapped in?
It will with a B110 automatic tunnel.
Posted on: 2010/8/24 5:36
Re: Tunnel Question
From Brisbane
I assume my car already has a bigger tunnel. I haven't been under the middle and haven't had the carpet out... but it has a CA18 box in it. It's a late 120Y.
Honestly, put the biggest tunnel in you can, it makes life so much eaiser.
Posted on: 2010/8/24 6:32
Re: Tunnel Question
all 120Ys have the larger tunnel
Posted on: 2010/8/24 7:05
Re: Tunnel Question
From Geelong, Vic
like i said, both 120y tunnels are the same
DD i can fit the stock heater in both of those tunnels. was a design consideration when i put them in as i wanted it all to look as stock as possible once it was done
not that the heater ever worked in my sedan...but it was in there
Posted on: 2010/8/24 7:25
Re: Tunnel Question
Quite a regular
From Canberra
Muchly appreciated fellas!
Now my next questions......Who has one they wanna sell me???
:P
Posted on: 2010/9/6 7:15
Re: Tunnel Question
and here's the 3rd one you did
bluebird tunnel i think it was, or stanza, not recomended
Posted on: 2010/9/6 8:30
Re: Tunnel Question
From Nyngan, nsw Australia
1200 auto tunnel been used to fit ca
Posted on: 2010/9/6 9:18
living is good,.....
