info on 3T-GTEU, or any small six into 1200
From Sydney
does anyone know if any six or the toyo engine fit? any info helps. is the 3s- engine too long?
Posted on: 2003/10/6 6:40
Re: info on 3T-GTEU, or any small six into 1200
From Melbourne AUS
there is a couple of pics on the site of v6's in 1200's.. and ive seen a 3.8 VN commo V6 in a coupe before, but with extensive mods to the tunnel to fit the auto in.....
Posted on: 2003/10/6 7:25
1973 B110 A12
From Mudgee NSW Australia
I have been helping with a VG20 into 1200 ute it fitted suprisingly well. I honestly think it will be pretty slow. quite a heavy engine with not much power.
A Vg30 quad cam turbo would be the go :) A frieind just has one running in his LH torana sick of spendiong a fortune on the old holden V8 and being thirsty grumpy and unreliable. Bolted the VG in its making more power sounds sweet and revs like a bitch :)
Andrew
Posted on: 2003/10/6 10:12
If In doubt run more BOOST
From Mandurah WA
3TGTEU Would be a hard fit into the 1200.
And the 3TGTEU isnt a 6cyl.
If your really searious look into a KLZE from a Mazda 626 and Mx6 1992 - 1997 Jspec engine.
200hp stock the only thing is they are mounted FWD for the 626 and Mx6 though shouldnt be too hard to swap too rwd.
Posted on: 2003/10/6 15:41
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
From Toowoomba, Qld, Aust,
Hey ca18det_man do you know if the twin cam heads of the vg30de will fit onto the vg20 ????????
Posted on: 2003/12/20 14:48
From California
This is the ultra-compact V6 twin-cam from the FWD Mazda MX-3 (U.S.):
Posted on: 2003/12/20 18:36
From Millgrove Vic OZ
They are different blocks on the Z32 engines, the heads do not inter change.
Posted on: 2003/12/21 0:35
Cheers Feral
