which model r31 had lsd diff does anyone know
Hi guys just wondering if someone could tell me which r31 model skyline had the lsd
Cheers leih
Posted on: 2010/9/2 4:18
Re: which model r31 had lsd diff does anyone know
From Gold Coast
pretty sure the silhoette and gts/gtsr models had them mate.. could be wrong tho
Posted on: 2010/9/2 4:20
From Brisbane
99% of silhouette and svd models had them
were also an option on lower spec ones i believe so you can fluke it sometimes
very hard to find though
Posted on: 2010/9/2 4:33
That sucks thought I might of found a bargain, I'm workin out west and a wrecker out here has 2 wagons and 3 skyline sedans all r31 and all have the diffs. one of the sedans has got irs, the other one is an executive, the 3rd is missing the badges
Posted on: 2010/9/2 4:40
From Nations Capital, Australia
Not all silhouettes; just the GTS had the LSD like wardy said. And there was only 200 of the older shape and 200 of the newer shape. That's why they are so dear. I'm pretty sure there wasn't any other Australian issued SVD (Special Vehicle Division) Skyline's. Not sure which of the import skylines had LSD though. They wouldn't be common either.
Posted on: 2010/9/2 8:14
From brisbane
Hi mate
I've got a complete disc to disc R31 diff and an LSD centre I would be prepared to sell.
The LSD needs a rebuild.
Shoot me a PM if interested.
Regards Matty
Posted on: 2010/9/2 9:07
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Perth
Its a BW78 ... the LSD out of Commodore and Falcon fit (if you have the correct axle splines)
Posted on: 2010/9/3 1:04
From Brisbane
correct
a vk lsd or non-turbo vl lsd should fit a pintara 25sp diff
a turbo/v8 lsd from a vl/vk should fit a skyline 28sp diff
later commodore live axle lsd (vn-vs non irs) should fit a skyline 28sp diff
please check out specific examples for yourself but in general this is true
i'm using a vl turbo lsd in my r31 diff
Posted on: 2010/9/3 2:10
if it's 25 spline - xe/f era fairmont ghia (I think is the name) and early EA ghias (definitely) had 25 spline lsd.. You can get new lsd friction cones from ebay cheap enough.
Be aware though that if it is a 2.77:1 ratio lsd, then the carrier is different, the crownwheel attachment point is shifted sideways (vs all other bw78 carriers for the other ratios) because hte pinion is bigger and needs more room.
You can run those carriers with different gears, you just need to make a sandwich plate about 2-3mm thick to space the crownwheel back closer to the pinion so that the available range of thickness of carrier bearing shims can be used to get teh backlash right.
Posted on: 2010/9/4 4:39
John McKenzie
From Western Australia
ALL nissan r31 silhouette and gts1 & gts2 (australian models SVD) had borgwarner live axle lsd's from the factory.
series 1&2 silo's (manuals) and gts1's (all were manual) had 3.7:1 all series 3 silo's, all autos and all gts2's were 3.9:1.as they were sold new in Australia.
many of the cars had diff problems (noise) under warranty and they were replaced with the later 3.9:1 units.
the other models could also be optioned with an lsd when purchased new.
jap import r31's have IRS with a long nose r200.
I hope this info is helpful.
Posted on: 2010/9/4 21:52
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
