« 1 (2)
Re: Who has intermittent wipers?
For 1978 and newer 1200s:
Posted on: 2010/9/9 4:59
1970-1978 wiper switch: square 6-connector with blue wires
1979-up Wiper Switch: rectangular 6-connector
The newer Wiper Switch looks much like a headlight switch, but has one blue wire.
Posted on: 2010/9/10 5:04
So here's the modification.
1. Connector for old 1200 harness at left.
2. Feed four of the wires straight thru:
* Low
* High
* Ground
* Washer
3. Cut the Park wire and send it to the Intermittent AMP box
4. On the new switch, feed the two different wires to the Intermittent AMP
The Yellow and Blue/Red wire go to the amp, then it sends the Park signal to the motor with either intermittent or regular operation. Pretty simple.
jpg  temp.jpg (28.39 KB)
174_4c8b1cc9f2f5b.jpg 400X208 px
Posted on: 2010/9/11 7:08
From Christchurch NZ
could you please sraw a diagram showing exactly which wires from each plug, go to exactly which wires on the other plug? The pic is good, but I'm a diagram kinda guy.
Posted on: 2010/9/11 8:38
Forced Induction!
Good idea. I tested this today and it works well. It sounds like a T/S (indicators) 'clunk' when it cycles on and off.
Posted on: 2010/9/12 4:57
You can wire the new switch like this (without the AMP) and it will work as stock. The first position will do nothing. But High and Low and OFF work as originally.
Adapter harness for new Wiper Switch into old 1200.
Posted on: 2010/9/12 5:03
Here is the basic "adapter harness" modified for use with the intermittent AMP. The wire colors are up to you.
The modication from the basic Adapter Harness is:
* the Park wire is cut and both ends sent down to (to the AMP)
* the new Intermittent wire (the sixth wire) is added. It goes down to the AMP too
jpg  wiper_intermittent.jpg (26.74 KB)
174_4c8c52abd9147.jpg 400X256 px
Posted on: 2010/9/12 5:10
I mounted the AMP (black box) on the pedal box, with the same screw that fastens the Flasher. I chose to earth it right there (black wire).
The connectors from an old Datsun wiring harness that had been cut. So in my 1200, there was no cutting of the harness at all to fit the intermittent switch and AMP.
jpg  wiper_intermittent_AMP.jpg (67.37 KB)
174_4c8c542908bdc.jpg 800X528 px
Posted on: 2010/9/12 5:16
Thanks DD. Now I need to get off my fat lazy arse and find the switch and delay box I sourced about 7 years ago.
Posted on: 2010/9/12 5:17
Forced Induction!
« 1 (2)
