how do u find out wat cranks is wat?????
From Bendigo Vic
hey
i have a crank i got for someone and i want to no want it is? he said it mite be a 1500 crack but he thinks it a 1400 crank, how do you tell the different between the 1400 to the 1500 crank?
thanks aidan
Posted on: 2010/9/10 10:22
Edited by aido on 2010/9/10 15:23:07
Re: need help with cranks
From Bendigo Vic
can anyone help me??
if not ill take it to work on monday they will no how to find out
Posted on: 2010/9/10 11:38
Re: how do u find out wat cranks is wat?????
From Bendigo Vic
can anyone help me?
Posted on: 2010/9/10 15:25
From hastings,vic
check the stroke
a15 is 82mm
Posted on: 2010/9/10 15:41
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Take the time to read the technical library that has been so carefully assembled by ddgonzal.
Be polite and do your own research before asking slack questions like "how do u find out wat cranks is wat?????"
Use the lump between your ears and research. If you get given a crank that MAY BE a 1500 or 1400 crank then begin with a question like: does it suit an A-series? What engine did it come from? Is it a FORD crank or is it an ISUZU crank or is it a Datsun crank? etc etc.
Posted on: 2010/9/10 16:34
From Bendigo Vic
it a datsun a-series crank and he had a box of bit for his datsun and he had a14 and a15 bits together so he did no wat the crank wasout of.
Posted on: 2010/9/11 0:00
From Bendigo Vic
had a read and could find how to measure the crank stroke so i just put the number on the crank(h6240) into fast search and it came up with an a14 crank so dont need ur help now.
thank tommo for that bit of info
Posted on: 2010/9/11 0:25
From Armidale N.S.W
Text speak = lazy ass.
Posted on: 2010/9/11 6:03
73 1200 wagon SOLD
I thought it was a good question. Measuring the throw is somewhat tricky...the casting number is certainly easier.
Posted on: 2010/9/11 6:12
