1200 coupe disc struts on sedan
From North Coast NSW
hey guys,
just wondering is there anything that needs to be changed, added or removed when putting 1200 coupe disc struts in a 1200 sedan?
thanks heaps Nick
Posted on: 2010/9/24 3:21
in need of 1200 coupe parts!
Re: 1200 coupe disc struts on sedan
master cyl possibly, you may be going from single master cyl to dual master for the disk brakes.
Posted on: 2010/9/24 3:59
* Master cylinder
* Rear brake cylinders (to match the stopping balance)
Posted on: 2010/9/24 6:06
alright guys too easy (: thanks heaps
Posted on: 2010/9/24 9:26
From Christchurch NZ
Hijack, but did sedans have drums over there in OZ? All our sedans came with discs as standard.
Posted on: 2010/9/24 21:47
Forced Induction!
yes B110 "Standard" models used front drum brakes (most Aussie sedans are STD models)
Posted on: 2010/9/25 2:36
In USA too, all sedans came with front disc brakes.
In Japan, STD and DX came with drums, while GX and GL came with discs.
Posted on: 2010/9/25 2:37
yeah i heard about that.... so im guessing 120y disc struts are the same as 1200 coupes??
Posted on: 2010/9/25 9:49
The 1200 Coupe struts are same as 1200 Sedan GL struts. The Sedan preceeded the coupe by about 3 months. The B210 with A12 struts have a different part number, but appear to be the same as B110 struts. B210 with A14 used larger struts.
First B110 off the line, January 1970
Posted on: 2010/9/26 4:45
