a15 dizzy terminals?
From adelaide hills
just wondering what the 2 blade terminals are for on the dizzy and what wires i need to run to them? any help? cheers
Posted on: 2010/10/2 3:43
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: a15 dizzy terminals?
From mandurah
put a pic up of what terminals you mean and then we can determin what they do
there is a terminal on one side of the dizzy that is earth and is located next to the vac advance actuator ,it shouldnt need hooking up
then there is another one that is mounted to the sude of the dizzy and has a piece of plastic in between it which is an isolator ,this goes to the - on the coil
if you want i can draw up a pic
Posted on: 2010/10/2 3:53
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
same as the A12 dizzy
one is ground/earth
one goes to Coil -
if it is an electrionical dizzy it may also have a Coil + wire.
Posted on: 2010/10/2 3:58
From adelaide hills
im pretty sure there wasnt one on the blade next to the vac advance when i pulled it out the other car but i cant remember, so the other one goes to which side of the coil?
Posted on: 2010/10/2 4:01
From mandurah
negative ,from the termianl on the side on the dizzy that faces the firewall
Posted on: 2010/10/2 4:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From adelaide hills
thanks for that
Posted on: 2010/10/3 1:22
