wiring tacho
From Brassall
just a quick question on the wiring of the tacho in the 1200 dash, i have 4 wires and 3 i am unsure of, i know the yellow is ign, i than have another coming out right next to the ign wire. than 2 wires coming out from a lower point anyone know which wires are wich? thx
Posted on: 2010/10/3 0:35
Re: wiring tacho
From Adelaide
Usually there's one for ignition signal, one for dash lights, one for power and one for ground. Red is usually power, black is usually ground and you can probably figure out the other one by grounding black and trying the other two with +ve and see when the light comes on. If unsure use a 9V battery since it wont do any damage if you hook it up wrong (they can't supply much current). Hope this helps.
Posted on: 2010/10/3 0:51
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: wiring tacho
im sure that someone on here would have a 1200 manual it has wiring diagram in them
Posted on: 2010/10/3 0:59
Re: wiring tacho
Posted on: 2010/10/3 1:13
Re: wiring tacho
From Brassall
got it sorted using info from the tech wiki page. thx!
Posted on: 2010/10/3 3:22
Re: wiring tacho
From Brisbane
also guys, i'm looking at hooking up a stock 120y tacho to a ca18
any tricks?
Posted on: 2010/10/4 7:05
Re: wiring tacho
no tricks, just works fine
Posted on: 2010/10/4 8:01
