« 1 (2)
Re: newbie question - threads in carb stripped
Go the 32/36, Probably the best upgrade you could get to begin with, that and some extractors.Both of which come up for sale here regularly at a fraction of the cost of an ebay $600 jobby. Clyon's estimate sounds about right.
Put a WTB ad up.I'm sure there's at least a few members here with one in the shed doing nothing.
I think you deserve one for the duct tape kludge and diagram alone ;)
Posted on: 2010/10/27 3:25
From West of Seattle
This is not a permanent fix, but easy and cheap. Cut a small piece of an aluminum can hold the piece carefully with a pair of needle nose and insert it in the carby and double nut the rod and spin into the carby. The aluminum will act as a heli coil. Put a piece of cloth in the carb first so as not to drop anythinf down the barrel. Hope this helps
Posted on: 2010/10/27 8:29
From New Zealand
i've got a little airfilter on mine that is held on with basically a big hose clamp the goes around the round to of the carb. No need for centre bolt and i've never had a problem with it in 4-5 years (touch wood). Cost $40ish??
Posted on: 2010/10/27 8:46
From Sydney
Hey are you tring to hold your whole air cleaner assemble with just that one stud/wingnut that goes through the center?? Cause i belive you are missing the two other brackets that hold the air cleaner lower housing to the manifold. that one bolt aint never going to do it alone and is really only to just hold the top plate and air filter in place. cheers tom
Posted on: 2010/10/27 10:25
Oh...I didn't realize there are brackets missing, its just the way it came when I bought it. :(
Posted on: 2010/10/27 10:29
I've been reading up on pod filters on the web and some people say that a pod filter on a carb actually reduces the performance of the carb since the stock air filter actually gets more air....this true?
By the way thank-you ericsb210!....your little trick is working while I wait to buy a 32/36 from someone. Cheers.
Posted on: 2010/10/29 14:22
Welcome
Posted on: 2010/10/30 6:29
« 1 (2)
