quick question, breather pipe into block
From Melbourne, Australia
id like to take out the sump breather so i can modify it for clearance
just wondering how it is installed? and any tips on getting it out, cheers
and, is the front radiator pipe the same story?
Posted on: 2004/1/7 22:11
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: quick question, breather pipe into block
From wodonga, victoria
its pressed in with a bit of ultra blue
Posted on: 2004/1/7 22:36
From Tas
Posted on: 2004/1/8 1:58
From GOLD COAST AUZ
Stilsens [monkey wrench] rotate it while pulling it out (2 person job).Bit of blue and hammer to put it back in.
Posted on: 2004/1/8 7:29
rather be a old fart than a young d##khead
Tap it gently with a soft hammer to loosen it a little, then wrap your hand firmly around it. Work it steadily for a little while, & as it gets close use short but fast motions & it will come out for you, no problem.
Reinstall[?] with some sealant & a hammer.
I never used Stilsens as they damage the shaft with nasty teeth marks.
Posted on: 2004/1/8 10:44
Love your Datsun.
Treat it well.
From GOLD COAST AUZ
HAY D-man thay only needed it out,if thay won`t it pretty, take it to a eng/shop.
Posted on: 2004/1/8 10:52
From Tas
Lets try and keep this forum clean please
Posted on: 2004/1/10 0:56
From Perth
Are you blanking it off with a core plug ?
Is this a problem ? as I intend doing this with my engine.
I plan to runb a dry sump so the engine will work in a vaccuum so I assume I can plug it without hurting anything.
Posted on: 2004/1/10 15:17
From Okinawa, Japan
Yes with a dry sump setup plugging this off won't create any issues... in fact you'd have to block it off somehow... weather taking it out and plugging it or just simply plugging the end.
Posted on: 2004/1/10 15:23
Buff
What are you talking about?
The question was about breather pipe removal, & thats what i responded to. I don't know what you have on your mind, but it can't be crankcase ventilation.
I use this method so that the spiggot isn't damaged & i can refit it after block cleaning & reconditioning.
Posted on: 2004/1/11 3:15
Love your Datsun.
Treat it well.
