« 1 ... 16 17 18 (19) 20 21 22 »
Re: supafatto's coupe project a14t then cadet
needles and seats sorted yet?
supafatto twisting something to go vroom vroom
if you go electric pump- dont for get fuel regulator too
Posted on: 2010/10/30 10:08
thats good to see it running, would also like to know what you sorted with the needle and what not
Posted on: 2010/10/30 11:52
still sorting stuff out need o2 sensor and exhaust and elec fule pump
Posted on: 2010/11/3 6:01
Car free
Nick sounds good over 2K, what is the brass T on the side of the manifold?
Do all early t25 all have carbon seals? any I should keep an eye on?
Posted on: 2010/11/3 11:30
d the car was cold too, it runs better warm!!
the brass t is 1.vac/boost to dizzy
2.booster line for breaks
3.small black hose to turbo kneck is boos gauge
as far as i no t25 are carbon seal i think, i havent done much research but heap of ppl have done t25 b4 and i have 2 or 3 differant types of t25s now so not sure will have to look and find out.
hope to have a few more parts comming from usa in the next few weeks as our dollar is so good time to buy b4 they tax everything on us
Posted on: 2010/11/4 10:16
Car free
I thought you were going to run a locked dizzie at 10 degrees like topgear did?
or does it still need the vac/boost to dizzie?
That was cold bugger me! how did you tune it so well?
Posted on: 2010/11/4 12:11
no im running a boost retard dizzy so still need vac/boost line
i need to run a elec fule pump as psi on stock pump dropps on boost :)
Posted on: 2010/11/5 5:32
Car free
exhaust is on and car is running a little beter but still runs out of fuel and is running lean :( so still some work to do
Posted on: 2010/11/6 11:01
Car free
some new toys,blank plate and malpassi fuel pressure reg, still to come!, su oil, returne spring, air filter.
jpg  117 skyline107.jpg (173.70 KB)
10308_4cdb9f960d448.jpg 1536X1152 px
Posted on: 2010/11/11 7:49
Car free
ok so a little update, ive just bought a water/meth setup from the states and a fule pump and a few other things, so i hope to get them soon and drop them off to tomoz's shop so he can fit all the stuff up and then he will be finaly be able to play around with the tune and get it running better as every time i play with it it just gets worse, lol. but has been fun driving it to try tune it. should be good with the water meth going and a tune i hope to get a dyno and have 130is i hope
Posted on: 2010/11/22 11:59
Car free
