Browsing this Thread:
1 Anonymous Users
steering tie rod ends b210 b310 |
From malta
hey guys. long time i didn't post in here
i occured to run into a problem
does the b310 and b210 exchange tie rods, tie rod ends and centre tie rod piece between each other???
10x in advance 4 ur help
jonathan
Posted on: 2010/11/4 16:49
Re: steering tie rod ends b210 b310 |
From Malaysia
if i am not mistaken, b310 use longer tie rod ends. you can use b210 tie rod ends in a b310. but it will be shorter.
Posted on: 2010/11/4 21:18
From malta
is that the only difference ??
and how about the centre rod???
Posted on: 2010/11/6 14:58
From Charlevoix, MI USA
The "centre tie rod piece" (center link or drag link) is not interchangeable because of where the idler arm attaches. The inner/outer tie-rods with adjustment sleeves can be nominalized to specs, and so are interchangeable. Strongly suggest a professional alignment is performed after replacement. https://acrobat.com/#d=ecMX4jwmR-Cy-nGhbBSIXghttps://acrobat.com/#d=FWjuh6qRfVkBsRLLzEFhXw
Posted on: 2010/11/6 15:14
"from the land of the graceless bumper" '78 B210GX BREwannabe'
From malta
10x mate that is a good explenation :)
Posted on: 2010/11/6 16:52
