« 1 ... 10 11 12 (13) 14 »
Re: LAGWAGON II the 1000 version... with no lag
why? why? why? do you have all the stock stuff still to bolt back in?
Posted on: 2010/11/30 10:39
dude! you really selling up? whats the plan?
Posted on: 2010/11/30 10:51
From Melbourne Vic
decided i only need and can afford one toy. the 1600 won the battle :(
It was too good a car to just use as a daily hack, its more of a pride and joy sort of car. Still have bits to put back to a12 but still have front disks and upgraded m/c etc
wheels are spoken for.. will still be seen on the site
Posted on: 2010/11/30 10:58
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Freo
:( you've done an awesome job, only wish it was over here and $$$
Posted on: 2010/11/30 11:10
A15 PSI Project Motor
'72 CB750k,
From Melbourne Vic
decided to have aplay with a turbo manifold. So the altenator has to be on the drivers side, the water pipe out of the block likely needs to be modified and the engine mount most defitely needs to be modified, which i have already done.
I really wanted to run it with a merge collector and pipes, just because i like them that way.
Posted on: 2020/8/13 4:41
From Melbourne, Australia
VERY COOL! will the dump pipe run between engine mount and sump?
Posted on: 2020/8/13 5:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne Vic
Cheers, i like how its turned out. The dump will run past the engine mount, basically straight through where it used to be
Posted on: 2020/8/13 8:27
From Melbourne,Australia
Need to change the thread title again haha
Posted on: 2020/8/13 23:46
Re: LAGWAGON II the 1000 version... with no lag (for now)
From Mordialloc Victoria 3195
Will you need a scavenge pump because the turbo is sitting low?
dp
Posted on: 2020/8/14 10:57
keep it simple
From Melbourne Vic
Ive got to double check that the drain sits above the oil line. How far below the block is your oil return ziggy?
Posted on: 2020/8/15 14:05
