Browsing this Thread:
1 Anonymous Users
sway bar questions...... |
From Seattle ,WA.
I'm installing a B210 20MM bar instead of the 17MM stock 110 version, the problem comes with the 210 (120?) bushings & bolt. How critical is the height of the bolt, the spacer & the bushes themselves?
laying the 210 bush setup next to the 110 setup - its about 1"+ higher then the 110 stock ones, I've gotten some shorter bolts that match the height of the original 110 bolts but then the space between the bushings is only about a 1/2" to 3/4" - do I shorten both the bolt & the spacer or does somebody have a tried and true method for this upgrade?
BTW - the stock 110 bushings are not available over here otherwise I'd use those & the originals I have are shot.
Has anyone ever made bushings to match the stock 110 ones?
Any idea's would be appreciated! Thanks, Evan
Posted on: 2010/12/6 3:52
Re: sway bar questions...... |
From Ringwood, Melbourne, AUS
I take it you are meaning the links at the end of the arms that connect to the LCA's?
I just fitted my 210 bar last weekend and re-used everything except the two D shaped bushes that mount the bar to the front chassis cross member, for those I used the 210 ones that came with the bar.
Posted on: 2010/12/6 4:04
Deano
From Seattle ,WA.
thats correct, I've got the U shaped brackets / caps that bolt the bar to the chassis, that connects up nicely, its the vertical bolts & bushings that are spec-ed for a B210 that seem to be the problem.
I think I can make it work if I cut down the spacer between the upper & lower bushings, I wondered if it'd cause some kind of a problem is all/
I did locate a part # for a Superpro poly bushing set but may have a difficult time locating one in the US. Part # SPF0903K, says its for a Sedan or Ute 1970 & up, I assume the sedan is the same as the coupe bushings???
Posted on: 2010/12/6 4:27
